Survey123ReportGetter_EnterprisePortal
  • Jun 9, 2025 7:00 PM UTC
  • 0 replies
  • 60 views
fmelizard
Forum|alt.badge.img+22
FME Hub user cratcliff just uploaded a new transformer to the FME Hub.
Description
Get a URL to a formated docx or pdf report file of your Survey123 record. - Modified version for Portal
Details
This transformer uses HTTPCallers to submit a report job to Survey123 and returns the report's URL after the job has completed. At the moment, only detail reports for a single Survey123 record are supported. You must create and upload a report template in Survey123 first. See ESRI's documentation for more information: https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereporttemplates.htm
This transformer can be used in a workspace within an FME Server automation that is triggered by a Survey123 webhook, allowing you to create a report as soon as a survey has been submitted.
Would you like to know more? Click here to find out more details!
