OpenAIConnector
  • Mar 25, 2025 1:00 AM UTC
  • 0 replies
  • 172 views
fmelizard
Forum|alt.badge.img+22
FME Hub user chrisatsafe just uploaded a new transformer to the FME Hub.
OpenAIConnector Transformer Documentation
The OpenAIConnector is a custom FME transformer that enables integration with OpenAI's /v1/responses endpoint. This transformer allows you to send prompts to OpenAI's large language models and receive responses directly within an FME workspace. This model accepts text, image (Vision), file search, and web search based inputs.
Purpose
This transformer supports AI-driven tasks such as content generation, classification, summarization, or transformation of structured/unstructured data, by leveraging OpenAI's text generation capabilities in a repeatable, automatable data workflow. The
Example Use Case
Imagine you have a dataset with a column of customer support inquiries, and you'd like to auto-generate a response or classify the sentiment. You can:
Use AttributeCreator to build a dynamic prompt string.
Pass that prompt to OpenAIConnector.
Capture the model's response as a new attribute for downstream use.
Output Attributes
Attribute Name
Description
_response_body
The raw text response from the OpenAI model.
Response
A formatted text response from the OpenAI model
Notes
This transformer uses the OpenAI completions API (/v1/responses). It is not compatible with the chat endpoint (/v1/chat/completions) unless explicitly adapted. For Chat Completions, consider using the OpenAIChatGPTConnector instead.
Related Resources
OpenAI API Docs – Responses
OpenAI Tokenizer Tool
Would you like to know more? Click here to find out more details!
