MinimumSpanningTree
  • Mar 21, 2024 7:00 PM UTC
  • 0 replies
  • 67 views
fmelizard
Forum|alt.badge.img+22
FME Hub user konnorporter just uploaded a new transformer to the FME Hub.
Takes a set of points with a start/end point and creates a minimum spanning length network/tree.
The parameter Start/End Node determines which node(s) to use as a seed for the algorithm.
0 or any false-ish value means not a starting node, while 1 (or any positive result) results in that feature being used as a starting node.
Placing a 0 in that parameter, or giving a parameter that is false-ish, will result in the first node being used as the seed.
Choosing multiple starting points will result in a forest of Minimum Spanning Trees, i.e. several disconnected networks. This is useful for if you want to add more nodes to a pre-existing network, by setting all the nodes in that network to 1, and the nodes yet to be added to 0.
Would you like to know more? Click here to find out more details!
