JpStdGridAccumulator
  • Sep 10, 2026 7:00 AM UTC
  • 0 replies
  • 9 views
fmelizard
Forum|alt.badge.img+22
FME Hub user takashi just uploaded a new transformer to the FME Hub.
Replaces the input features with a grid of polygons or points based on the Japanese geographic mesh dividing standard.
Resulting polygons or points will cover all the input features, and the output features will have a new attribute storing its mesh code.
Notes:
This transformer is valid only for a geographic data on Japanese area with LL coordinate system.
Unavoidable slight computational errors caused by calculation for floating point numbers may occur in the resulting coordinate values. Consider applying the CoordinateRounder or something similar operations to absorb such errors if necessary.
This transformer supports these Japanese standard grid types.
- Primary Standard Mesh - spacing (W x H): 3600sec. x 2400sec., mesh code format: "AABB"
- Secondary Standard Mesh - spacing (W x H): 450sec. x 300sec., mesh code format: "AABB-CD"
- Tertiary Standard Mesh - spacing (W x H): 45sec. x 30sec., mesh code format: "AABB-CD-EF"
- 1/2 Subdivided Mesh - spacing (W x H): 22.5sec. x 15sec., mesh code format: "AABB-CD-EF-G"
- 1/4 Subdivided Mesh - spacing (W x H): 11.25sec. x 7.5sec., mesh code format: "AABB-CD-EF-G-H"
- 1/8 Subdivided Mesh - spacing (W x H): 5.625sec. x 3.75sec., mesh code format: "AABB-CD-EF-G-H-I"
- 1/10 Subdivided Mesh - spacing (W x H): 4.5sec. x 3sec., mesh code format: "AABB-CD-EF-XY"
A - I, X and Y in the formats represents a digit determined by the followings.
AA = south end latitude (degrees) of the (parent) primary mesh * 1.5
BB = west end longitude (degrees) of the (parent) primary mesh - 100
C = row index in the parent primary mesh (0:south - 7:north end)
D = column index in the parent primary mesh (0:west - 7:east end)
E = row index in the parent secondary mesh (0:south - 9:north end)
F = column index in the parent secondary mesh (0:west - 9:east end)
G = 1:left-bottom, 2:right-bottom, 3:left-top, 4:right-top in the parent tertiary mesh
H = 1:left-bottom, 2:right-bottom, 3:left-top, 4:right-top in the parent 1/2 subdivided mesh
I = 1:left-bottom, 2:right-bottom, 3:left-top, 4:right-top in the parent 1/4 subdivided mesh
X = row index in the parent tertiary mesh (0:south - 9:north end)
Y = column index in the parent tertiary mesh (0:west - 9:east end)
Would you like to know more? Click here to find out more details!
