HexagonTiler
  • Jul 1, 2026 1:00 PM UTC
  • 0 replies
  • 13 views
fmelizard
Forum|alt.badge.img+22
FME Hub user edwardburton just uploaded a new transformer to the FME Hub.
Replaces the input polygon with a grid of regular hexagons of the specified size and in the selected tiling mode.
Inputs
Polygon Input
The polygon required to be replaced by a tile of hexagons.
Parameter
Hexagon Circumradius
The required size of the hexagon tiles. The circumradius is the length between a vertex and the centre point of the hexagon.
Tiling mode
Clipped to polygon extents
The hexagon tiles will be clipped to the shape of the polygon they're replacing. This will leave the outermost tiles no longer hexagon shaped.
Intersecting polygon
Any tiles intersecting the input polygon will be output. This will include any tiles that extend beyond the boundary of the polygon.
Contained within polygon
Only tiles fully contained within the input polygon will be output. This means the tiling will not fully cover the input polygon, but will leave spaces between the outermost tiles and the polygon boundary.
Outputs
Tiles
The hexagon tiles
Centre_Nodes
Points at the centre of the hexagons
Edges
The lengths between the verteces of the hexagon.
Edge_Nodes
The verteces of the hexagon tiles.
Would you like to know more? Click here to find out more details!
