GeoApps Dataset Truncate
  • Apr 3, 2025 10:00 AM UTC
  • 0 replies
  • 35 views
fmelizard
Forum|alt.badge.img+22
FME Hub user wghmapgear just uploaded a new transformer to the FME Hub.
With this transformer, you can easily truncate all features from an existing dataset in GeoApps. This connection is for example useful for automated updating of datasets where you first want to remove the old data. To complete a setup like this, take also a look at our other transformers.
Prerequisites
To use this transformer, you need to have an active GeoApps subscription and a user account with enough permissions to run the jobs. In addition, you need to first set up a web connection to GeoApps from FME. You can find the web connection in the FME Hub at https://hub.safe.com/publishers/mapgear/web-connections/geoapps.
How to use?
Add the transformer in your workspace, and configure the parameters. You need to set up two parameters: the GeoApps workspace name, dataset id and the web connection to GeoApps. You can find the dataset Id within your GeoApps workspace.
Questions?
Do you need any help? Feel free to contact us at support@geoapps.nl.
Would you like to know more? Click here to find out more details!
