GeoApps Attribute Name Verifier
  • Jun 14, 2025 2:00 PM UTC
  • 0 replies
  • 30 views
fmelizard
Forum|alt.badge.img+22
FME Hub user wghmapgear just uploaded a new transformer to the FME Hub.
Eliminate data compatibility issues before they happen! With this transformer, you can easily verify that your feature attributes in FME are fully compatible with GeoApps, saving you time, preventing errors, and ensuring smooth data workflows.
Perfect for data professionals who demand reliability and efficiency in their geospatial data preparation workflows. Whether you're working with complex enterprise datasets or simple feature collections, this transformer helps you in every way when transferring data to GeoApps.
⚡ Key Features & Benefits
SImplify your data preparation workflow with these capabilities:
🔍 Automated Compatibility Validation: Instantly verify that attribute names meet GeoApps standards - no more guesswork or trial-and-error uploads
💡 Intelligent Error Diagnostics: Get clear, actionable error messages that tell you exactly what's wrong and why, eliminating confusion
🛠️ Smart Name Suggestions: Receive compliant attribute name recommendations that maintain your data's meaning while ensuring compatibility
⚡ Zero-Configuration Setup: Works out-of-the-box with no complex parameters to configure - just add and run
Important: If you're using our other GeoApps transformers for direct data writing, this validation happens automatically! The Attribute Name Verifier is seamlessly integrated into our direct-write transformers, so you get the benefits without any extra setup. This standalone transformer is perfect for manual upload workflows and quality assurance processes.
❓ Need Help? We're Here for You!
Not sure where to start? Or any issues with our transformers? Our dedicated support team is ready to help you. Whether you're troubleshooting a specific issue, optimizing your workflow, or planning a complex data migration, we've got you covered.
Get in Touch:
🛜 Support: support.geoapps.nl
📧 Email: support@geoapps.nl
🚀 Response Time: Typically within 1 business day
💪 Expertise: Direct access to the developers who built these tools
Would you like to know more? Click here to find out more details!
