FMEFlowFailedJobsReportGenerator
  • Mar 28, 2025 1:00 PM UTC
  • 0 replies
  • 47 views
fmelizard
Forum|alt.badge.img+22
FME Hub user martin_ekstrand just uploaded a new transformer to the FME Hub.
Generates a customizable HTML report of failed jobs using the FME Flow REST API.
This transformer retrieves all failed jobs from FME Flow and outputs an HTML report that can be emailed or embedded in a dashboard in FME Flow.
The report's appearance can be customized by modifying the CSS.
You can split the report based on job attributes—for example, generate separate reports for jobs triggered by Automations versus those started via Workspace Apps.
Additionally, the raw feature output is available if you prefer to build your own custom reports or workflows.
Would you like to know more? Click here to find out more details!
