BRGTabs
  • Jun 30, 2025 2:00 PM UTC
  • 0 replies
  • 28 views
fmelizard
Forum|alt.badge.img+22
FME Hub user alexbiz just uploaded a new transformer to the FME Hub.
BRGTabs collects multiple BRGComponent features and renders them as a tabbed section within an HTML report produced by the BetterReportGenerator (BRG) framework. It allows end‑users to switch between different report components seamlessly.
Parameter
Type
Default
Description
Title
String / Attribute
Tabs
Heading displayed above the tab set.
Order
Integer / Attribute
0
Numeric value used by downstream generators to position this component among its siblings.
Group By
Attribute Name
(none)
Name of an attribute whose distinct values will be used to group input features into separate tabs.
Would you like to know more? Click here to find out more details!
