AttributeTableFlightSimulator
  • May 30, 2025 12:00 PM UTC
  • 0 replies
  • 50 views
fmelizard
Forum|alt.badge.img+22
FME Hub user andreas_h just uploaded a new transformer to the FME Hub.
AttributeTableFlightSimulator Custom Transformer
Transform your attribute tables into an interactive HTML-based flight simulator game! This custom transformer takes your FME attribute table and converts it into a dynamic gaming experience where you pilot the table itself.
Input:
* An attribute table.
Tip for Optimal Gameplay:
* The flight simulation will run smoother and be easier to win with fewer attribute fields and rows in your input table. Use for example a Sampler and a AttributeKeeper to make your attribute table manageable.
Output:
* HTML content ready to be written out using an FME HTML writer, creating your playable attribute table flight simulator.
Use With:
* HTML Writer
Gameplay: How to Soar!
Objective: Fly your attribute table through a series of glowing hoops to accumulate points.
Key Rules:
Ranking Up: Gather points by successfully navigating through hoops. Achieving higher scores will allow you to attain new ranks and unlock prestigious titles.
Table Integrity - Don't Lose Your Data!: Be vigilant! If your score drops to zero, the data rows within your attribute table will begin to disappear one by one. Protect your data by keeping your score up!
Score Decay: Time is of the essence! Your score will gradually decrease over time. You'll need to stay active and continuously score points to maintain your rank and safeguard your table.
Hoops:
Regular Hoops: Successfully flying through these will award you standard points.
Special Purple Hoops: Keep an eye out for these! Navigating through purple hoops will grant you a higher point value.
Would you like to know more? Click here to find out more details!
