ArcGISAutomagicDocumenterSDETablesMetadata
  • Sep 30, 2024 11:00 AM UTC
  • 0 replies
  • 44 views
fmelizard
Forum|alt.badge.img+22
FME Hub user martin_ekstrand just uploaded a new transformer to the FME Hub.
Fetches metadata for all tables in an ArcGIS Enterprise geodatabase.
Outputs raw data and a metadata_html meant to be used as an optional input for ArcGISAutomagicDocumenterReportGenerator. If you want to create a custom metadata_html, you can use the raw data to overwrite the metadata_html attribute before connecting to ArcGISAutomagicDocumenterReportGenerator.
This transfomer is part of the ArcGISAutomagicDocumenter series. It is meant to be used together with the other transformers, but it can also be used on is own.
Sample workflow for the ArcGISAutomagicDocumenter series can be found here
Note: this transfomer can be very slow, especially for large databases - you may want to write the result to a database table instead, and use that table as input for the ReportGenerator
Would you like to know more? Click here to find out more details!
