ArcGISAutomagicDocumenterSDEDatabaseSchemaReport
  • Mar 5, 2026 3:00 PM UTC
  • 0 replies
  • 31 views
fmelizard
Forum|alt.badge.img+22
FME Hub user martin_ekstrand just uploaded a new transformer to the FME Hub.
This transformer is a part of the ArcGISAutomagicDocumenter series and is meant to be used as input for the ArcGISAutomagicDocumenterReportGenerator, but it can be used on it's own to just generate schema reports.
Uses a connection file to run the arcpy.management.GenerateSchemaReport tool that exports a database schema report in html format (one file per database).
Would you like to know more? Click here to find out more details!
