API Data: JSON to SpatiaLite
  • Oct 24, 2024 8:00 PM UTC
  • 0 replies
  • 15 views
fmelizard
Forum|alt.badge.img+22
FME Hub user lizatsafe just uploaded a new template to the FME Hub.
Purpose & Objectives
This workspace retrieves closed road JSON data from an API, fragments and flattens the JSON response into line features with attributes, and then writes the data out to a SpatiaLite database.
Key Transformers
Creator: Creates a single feature to trigger the workspace
HTTPCaller: Makes a GET request to the data source
JSONFragmenter: Fragments JSON into FME features and attributes
Data Source(s) - Reader Feature Type
A GET request to Vancouver Open Data:
https://opendata.vancouver.ca/api/explore/v2.1/catalog/datasets/road-ahead-current-road-closures/records?limit=5
Data Output - Writer Feature Type
VanRoads.sqlite SpatiaLite
Parameters:
Table Name: Closed
Geometry: db_linestring
Customization
To customize this workspace, it is recommended to build the workspace from scratch as your dataset will have different attributes and schema (structure). Instructions to build this workspace: Getting Started with FME Form: Working with Web Data.
Additional Resources
SpatiaLite Reader/Writer
Tutorial: Getting Started with JSON
Visual Preview
For help with this workspace, please contact Safe Software Support and reference API Data: JSON to SpatiaLite Gallery Example.
Would you like to know more? Click here to find out more details!
