If I set up azure ad in Authentication Services, will I be able to read and write from an external azure fileshare which use azure ad authentication?
  • October 7, 2022
  • 13 views
paalpedersen
Forum|alt.badge.img+7
I wonder if I setup azure ad authentication service on my FME Cloud instance, would I be able to read and write drirectly from a azure fileshare?
sourceFile //xxx.file.core.windows.net/yyy/source.ext
destinationFile //xxx.file.core.windows.net/yyy/destination.ext
Is this a common thing?
evieatsafe
  • October 13, 2022
@Paal Pedersen​ i believe the answer and how to do it is in this article: https://community.safe.com/s/article/Configuring-FME-Server-for-Azure-AD-SAML-authentication
