WORKSPACE_NAME dereferenced?
  • Nov 11, 2024 8:32 AM UTC
  • 1084 views
tb09114
Forum|alt.badge.img+28
We just installed FME Flow 2024.1.2.1 on a Windows machine and I published a workspace. Running the workspace immediately ends in:
Undefined macro `WORKSPACE_NAME' dereferenced in file `flow_testing\sqlserver_test_delete\sqlserver_test_delete.fmw'
The workspace was published from an ArcGIS Interoperability Workbench [FME(R) 2024.0.1.0 (20240328 - Build 24202 - WIN64)], but I tried the same from FME Form 2024.2. The result is the same.
The workspace is as simple as it gets. Just a reader and a writer, and the error appears independent if there is a name for the workspace set or not.
Can somebody please point me the right direction to solve the issue?
kate-safe
Forum|alt.badge.img+11
  • Nov 13, 2024 1:03 PM UTC
Thank you for your post!
There are a couple of things here:
  • First, it’s important to publish between the same version of FME Form and Flow - so publishing from 2024.2 Form to 2024.1 Flow is not going to work.  As well, publishing from an older Form (2024.0.1) to a newer Flow (2024.1) can also cause problems.
  • Are you able to try publishing from the same version of Form to Flow and do you see the same issue?
  • Are you able to share the workspace with us that you are creating in ArcGIS Interop?
Thank you,
Kate
tb09114
  • Nov 13, 2024 3:56 PM UTC
Hi, yes I realized today that it is possible to publish from the Data Interop Workbench and the workspace run is successful.
The compatibility check of Form and Flow (which I checked to late) clearly states that Form 2024.2 will not work with Flow 2024.1. I downgraded Form…
So, all good. 😊
kate-safe
  • Nov 13, 2024 5:52 PM UTC
Wonderful!  Glad to hear things are working now!
