Warning regarding "pkg_resources" since upgrade
  • Aug 6, 2025 2:37 PM UTC
  • 452 views
pmcpherson
Forum|alt.badge.img+11
Since recently upgrading FME Form to Build 25609, I’m seeing the following warning on startup.
UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
There are no obvious problems, but I would like to suppress the warning. Any ideas on how to accomplish this? Thanks.
hkingsbury
Forum|alt.badge.img+73
  • Aug 6, 2025 10:18 PM UTC
I don’t think you will be able to suppress just this warning without suppressing all others
