Using deployment param through scripted param UI errors off; bug?
joaniegeo99
FME(R) 2023.1.1.0 (20230928 - Build 23631 - WIN64)
I have a simple scripted parameter script in workbench to return the value of a deployment parameter and I’m wondering if there’s a bug in the interface. When I drag a user parameter onto the script canvas the code generated contains FME_MacroValues, eg.
FME_MacroValues['SomeUserParam']
If  I drag a deployment parameter, dpTest, onto the script canvas the code generated looks like
$(dpTest)
Here’s the script. The commented code fails; if I manually correct $(dpTest) to FME_MacroValues['dpTest'], it runs:
# Get the archive folder from deployment param
import fme
#arch = $(dpTest)
#return arch
return FME_MacroValues['dpTest']
Is this a bug? Thanks.
Best answer by mattmatsafe
Hi @joaniegeo99, thanks for reporting this! It is indeed a bug. We’ll get that fixed for a future release of FME. The workaround, as you’ve already found, is to manually correct the parameter format in the script. Apologies for any confusion and inconvenience this caused.
mattmatsafe
Forum|alt.badge.img+13
  • March 18, 2024
mattmatsafe
  • August 5, 2024
Please note that this has been fixed in FME 2024.1 b24555+
