"There was an error submitting the job" running under AD account
  • May 8, 2025 10:56 AM UTC
  • 162 views
lifalin2016
Forum|alt.badge.img+42
Hi list.
I have a local FME Flow development setup using 2024.2.3
Originally all of its 4 services ran as Local System, but the workspaces need to access files on a file share on another server, and so I tried changing the services (except database) to Local Network Service without much success.
Our production servers (2022) do run with an AD account, so I have som experience with this approach. I therefore changed the development Flow to run under my AD account.
The interface seems to be working ok, but now whenever I try to run a workspace, it errs with “There was an error submitting the job”.
Why is this different ? What am I missing here ?
Any insight is appriciated.
Cheers
dylan.at.safe
Forum|alt.badge.img+9
Hi ​@lifalin2016,
While FME Flow was running under the Local System account, were you able to submit jobs successfully?
In my own experience, on a local machine with no additional configurations (like HTTPS, SSO, etc), the “There was an error submitting the job” message is often caused by a misconfigured Service URL.
A few things to check:
  • Are engines registered and available in Flow?
  • Are you accessing the web interface via localhost or the machine name?
  • Do the Service URLs use localhost or the machine name?
Also, I’ve seen this error occur when connected to a VPN and accessing Flow via the machine name, whereas it works fine when off the VPN.
General help article on this topic: https://support.safe.com/hc/en-us/articles/25407409320845-FME-Flow-Run-Workspace-There-was-an-error-submitting-the-job
Dylan
