(Stuf-geo) plugin on FME FLOW not found
  • Jul 4, 2024 7:22 AM UTC
  • 201 views
cyrusa
Forum|alt.badge.img+8
Hi all,
In our company we are using FME Flow, it's works great.
Except with one workspace we get some errors. On the desktop version is works flawlessly! The error we get is about a plugin (STUF-GEO) that cannot be loaded:
144 2024-7-3 21:48:01 | File C:\Program Files\FMEFlow\Server\fme\metafile\STUF-GEO.fmf could not be opened
148 2024-7-3 21:48:01 | Could not load module 'C:\Program Files\FMEFlow\Server\fme\plugins/STUF-GEO.dll' : 'The specified module could not be found'
149 2024-7-3 21:48:01 | Could not load module 'C:\Program Files\FMEFlow\Server\fme\STUF-GEO.dll' : 'The specified module could not be found'
150 2024-7-3 21:48:01 | This FME edition does not recognize the `STUF-GEO' reader. Please ensure that the current platform supports this reader, the reader name is spelled correctly, and that you have installed all required plug-ins
151 2024-7-3 21:48:01 | This FME edition does not recognize the `STUF-GEO' reader. Please ensure that the current platform supports this reader, the reader name is spelled correctly, and that you have installed all required plug-ins
152 2024-7-3 21:48:01 | The below feature caused the translation to be terminated
186 2024-7-3 21:48:01 | FeatureReader_stuf_geo_<Rejected> (TeeFactory): FeatureReader_stuf_geo_<Rejected>: Termination Message: 'FeatureReader_stuf_geo output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
FORM: FME(R) 2023.1.0.0 (20230825 - Build 23619 - WIN64)
FLOW: FME Flow 2023.1.1.1 / Build 23636 - win64
Does anyone has an idea how to solve this issue? We are just users of FME Flow and not adminstrators/IT!
Thanks a lot,
Alan
geomancer
Forum|alt.badge.img+70
  • Jul 4, 2024 10:26 AM UTC
STuF-Geo is a custom format. To use custom formats and custom transformers in FME Flow you have to upload them to FME Flow.
Usually you do this while uploading a workspace from FME Form to FME Flow. But you can also upload custom formats and custom transformers manually.
See this page for more information.
cyrusa
  • Jul 10, 2024 5:39 AM UTC
Dear Geomancer!
Thanks for your answer. I read and followed the instructions, but without success.
I will escalated to our IT FME Administrators.
Thanks again.
verdoodtdries
Forum|alt.badge.img+23
Hi @cyrusa,
In FME Form, you can find the location of the custom format in the log-file, if you add a Reader to the Workspace.
Reading schema from custom format 'C:\Users\DriesVerdoodtNordend\AppData\Roaming\Safe Software\FME\FME Store\Formats\STUF-GEO.fds'
Next, you can copy this file to the resource folder Resources/Engine/Formats.
Hope this works for you!
Kind regards, Dries
