Questions about Flow in place upgrade from 2022.2 to 2024
  • Feb 14, 2025 7:48 PM UTC
  • 155 views
emo10001
Forum|alt.badge.img+4
We are currently running FME Server 2022.2. on prem (not cloud hosted).  We had been planning on upgrading to the latest, but now even more so with the privilege escalation issue, and there apparently not being a fix for our version….except to upgrade.
Looking over the “in place upgrade” portion of the documentation, it seems we can simply backup the configuration files (we’re not using version control yet), do an uninstall of 2022.2, do a fresh install of the latest 2024, and then restore the configuration backup.
Are there any known issues with doing this from 2022 to 2024?  I know the product was rebranded in 2023, but the differences I could see between 2022 and 2023 seemed mostly cosmetic for the rebrand.  However, I know 2024 seems to be different.
I just really want to dot all my i’s and cross all my t’s, and keep any down time to a minimum.  And know if there are any “gotchas” that can be avoided.
Thank you.
merlinegeorge
Hello,
As you have already identified and read through the in-place upgrade documentation, we would recommend data quality checks for the workspace translations and robust UAT post system restore. The known issues would be very specific to your setup and we recommend you look over https://support.safe.com/hc/en-us/articles/34243509378061-Known-Issues-in-FME to identify which ones might affect your setup.
Also when performing a Backup & Restore of an FME Flow configuration, you must restore to an FME Flow that uses the same custom encryption key as the backup.
In case of any issues during upgrade, please reach out to us via case ticket- https://support.safe.com/hc/en-us/p/Support
