Is there any additional configuration required after configureSSL.ps1 script has been run
  • Oct 10, 2026 1:18 AM UTC
  • 0 replies
  • 63 views
anryan
Forum|alt.badge.img+8
Hi there,
I have installed FME Flow 2026.3 with HTTPS enabled in the wizard and completed the items that were missing from Configuring FME Flow for HTTPS: Using a PFX or P12 Certificate – FME Support Center
This implementation didn’t work with an http 500 error.
I started again with clean infrastructure with HTTP only and this worked. I ran the configureSSL.ps1 script and now it’s working with HTTPS which is great.
Looking at Configuring FME Flow for HTTPS: Using a PFX or P12 Certificate – FME Support Center and comparing it to my configuration files and noticed configuration missing from the documented steps/part of steps.
Does the configuration need to be updated with these missing configurations (eg. ws:// to wss://, turn off OpenSSL support using Tomcat native)?
Thanks
