Is 'Configuring for HTTPS' still required after using the HTTPS and certificate option from the installer
  • Apr 27, 2026 3:27 AM UTC
  • 90 views
anryan
Forum|alt.badge.img+8
Hi there,
I have installed FME Flow 2026.1 and have used the HTTPS option with a pfx certificate from the installer wizard on Windows Server 2022 AWS EC2.
I can open the WebUI with https:// and everything looks fine and log in with SSO/SAML. The ‘Services’ page has the urls as https:// as well.
Question: Is the steps in ‘Configuring for HTTPS’ still required?
Best answer by mattconsortech
If the certificate was not self signed and was delivered by a certificate authority, just adding the certificate during the installation process (as you did) should be enough.
If you can access the web interface and run workspaces from your current configuration, then the steps in the Configuring for HTTPS tutorial are not needed.
Cheers,
Matthieu@Consortech
mattconsortech
Forum|alt.badge.img+15
  • Apr 27, 2026 5:00 PM UTC
Cheers,
Matthieu@Consortech
anryan
  • Apr 27, 2026 9:37 PM UTC
​@mattconsortech yes my cert is from our own CA. Thank you for your help.
