If we upgrade the current license manager will it still work with 2022.2
  • Sep 18, 2024 9:14 AM UTC
  • 184 views
annette2
Forum|alt.badge.img+11
Hi all,
We are planning the release of our upgrade FME 2024 package and the upgrade of our license manager.
If we go ahead and upgrade the license manager will it still work with the older 2022 clients?
We have a short overlap period during testing where both versions are in use.
Thanks,
Annette
donalmateer
Forum|alt.badge.img+13
Hi Annette,
Yes, if you upgrade the FME License Manager, it should still work with FME Desktop or Server version 2022.2, as long as the License Manager version is compatible with that release.
The following article may also assist in your query - Upgrading your Floating License to FME Form 2023 and Newer.
Also an FYI -  you may have remove the old license files from existing FME Form machines, you can learn more about this in the following article - FME Floating License Server: How to Upgrade FlexLM on the Same Machine.
