FME Server/Flow HTTPCaller Fails with Web Connection but works on Desktop/Form
  • Mar 4, 2025 6:25 PM UTC
  • 5 replies
  • 319 views
michaelh
Hi! I could use a hand.
I'm running an FME workspace that downloads data from ArcGIS Online using 4 HTTPCallers and a Web Connection. The workflow works fine in FME Form 2024, but when I publish and run it in FME Flow 2024.1, it fails.
Setup:
  • Using a Web Connection to authenticate (ArcGIS Online).
  • The Web Connection exists in FME Server and is assigned to my user.
  • The Web Connection is correctly assigned in FME Server.
Does anyone have experience with this issue? Could it be related to permissions, token handling, or FME Server settings?
Any suggestions would be greatly appreciated!
Best answer by bjarne
Try:
1. Re-autenticate the web connection.
2. Publish the workspace to fme flow and upload the web connection.
nielsgerrits
Forum|alt.badge.img+67
Anything in the log on server? Warnings or errors.
bjarne
Forum|alt.badge.img+5
  • Mar 4, 2025 8:13 PM UTC
Try:
michaelh
  • Mar 5, 2025 6:31 PM UTC
Thank you, ​@nielsgerrits. We are seeing the error in the attached. As one might expect, the URL, group name, and token information follow the error in this screen shot. We are giving your solutions a go as we speak ​@bjarne .
michaelh
  • Mar 14, 2025 7:01 PM UTC
Thank you both! Re-authemticating the web connection did the trick.
bjarne
  • Mar 14, 2025 7:32 PM UTC
