FME Server as POST Endpoint
  • Nov 11, 2024 12:08 PM UTC
  • 81 views
elmido13
Forum|alt.badge.img+4
 How to setup FME Server as POST Endpoint capable of receiving HTTPS requests from AWS’s source IP range.?
hkingsbury
Forum|alt.badge.img+73
  • Nov 11, 2024 8:03 PM UTC
Have you set your Flow instance up to be accessible externally?
https://docs.safe.com/fme/html/FME-Flow/AdminGuide/configuring_for_https.htm
If you have, and you’re still having issues, it’s likely there are either outbound firewall rules blocking the connect to FME on the AWS side, or there are inbound firewall rules blocking AWS on the FME/Infrastructure side
elmido13
  • Nov 11, 2024 8:31 PM UTC
Thank you for your response. No we haven’t . It is only accessible internally. Is the link provided will guide us through on how the instance to be accessible externally?
