FME Server 2019 MSI
  • September 9, 2024
  • 23 views
timboberoosky
I’m looking to uninstall FME Server 2019.1.3.1 from an old machine. When it was originally installed, it came as an executable file, not msi. Uninstalling from Programs and Features brings up the below message, and if I attempt using the exe instead, it unpacks everything and then gives me the same message. Is there an actual .msi for this? The Safe downloads site only goes to v2021, and even then it’s an exe not an msi.
Thanks!
timboberoosky
  • September 9, 2024
Thanks!
Never mind the exe extracted the msi, I just didn’t know where it put it. Problem solved.
