FME Flow unavailable services
  • Feb 10, 2025 4:09 PM UTC
  • 182 views
albinepro
Forum|alt.badge.img+7
I’m trying to publish a new app on FME Flow, but there are no services listed to create the app.
If I try open an existing app, it says “You do not have access to the "fmedatastreaming" service.” I’m logged as a admin with all possible rights.
If I go to services settings, all seems normal.
So Im not able to create any app and practically run any workspace. What could have gone wrong?
EDIT:
After updating to FME 2024.2.3 the problem stays exactly the same.
Best answer by albinepro
I have resolved the issue by first matching the major versions of FME Form and Flow. Later I published again the workspace makin sure that the services are registered with proper parameters set.
Later I could setup the workspace application scuccessfully.
albinepro
  • Mar 17, 2025 4:39 PM UTC
