FME Flow - job did not complete
  • Jan 23, 2026 9:08 AM UTC
  • 120 views
nordpil
Forum|alt.badge.img+13
We just upgraded to FME Flow 2025.2.1 and are now seeing some odd errors in our nightly data automation. Two nights in a row we have had jobs stopping at the same spot, there is nothing in the job log, and the job just fails with the message Job did not complete. When I look in the Windows event log (SYSTEM) for the server I can see a note of a “Fail Fast Exception” in fmeengine.exe - has anyone else seen anything like that?
shirleychan
Forum|alt.badge.img+9
Hi ​@nordpil ,
A Fail Fast Exception usually occurs when the job runs into an unexpected error. Unexpected errors may include running out of memory or a corrupt workspace component.
Because the jobs stop at the same spot, the error may be coming from a corrupt workspace component. The job log file lists the sequence of transformers and can show you the point where it stops working. This can help identify the transformer/reader causing the error.
To troubleshoot, check if the workspace successfully runs in FME Form. Upgrades in FME Form and Flow can introduce small changes in transformers/readers/writers and sometimes corrupt them when you open a legacy workbench in a new version of Flow and Form. To correct the corrupted components, delete the transformer/reader/writer and re-add them to the canvas.
I hope this helps. If the issue still exists, please feel free to submit a support ticket.
Thank you.
-Shirley
