FME Flow 2024.x URL
  • June 25, 2024
  • 51 views
mmccart
Forum|alt.badge.img+17
In the 2024.x versions of FME Flow, will the URL continue to contain ‘fmeserver’ or will it be changed to ‘fmeflow’? Example: https://mydomain/fmeserver vs. https://mydomain/fmeflow
If, by default, the URL will continue to have ‘fmeserver’ in it, can we change that in a configuration file?
Asking as we may need to run both FME Server 2022.x and FME Flow 2024 in parallel while migrating some legacy 32-bit Esri solutions.
Thanks,
Mark
Best answer by siennaatsafe
Hi @mmccart ,
As of today we have no plans to change the URL. For 2024.x it should stay as it is (/fmeserver).
It’s a lot of development work to change the URL so unfortunately it’s a lot more complex than a config file change.
siennaatsafe
Forum|alt.badge.img+11
  • June 27, 2024
Hi @mmccart ,
