FME Flow 2023 GDB/GPKG writter with fanout expression not working
catherinevachon
Does the fanout expression is available on FME FLOW 2023 ?
My FME Workbench works well on FME Server 2020, but on FME Flow, I got an error that mention that I don’t have the permission to write in the specific folder, but I have that permission.
For example, the Destination Fanout is $(FME_SHAREDRESOURCE_DATA)/temp and the Fanout Expression is /gpkg/test_@Value(attribut).gpkg.zip. I got this error message:
MULTI_WRITER: Failed to create folder '/gpkg/test_hello.gpkg.zip'. Please ensure you have sufficient permissions to create this folder
It seems like Destination Fanout is not taken into account.
liamfez
Forum|alt.badge.img+35
  • May 2, 2024
Do you get the same error if you run it without the .zip at the end?
catherinevachon
Thanks for your answer. I get the same error when I run it without the .zip at the end.
I was able to write the GPKG with Feature Writer. I created an attribute that combines $(FME_SHAREDRESOURCE_DATA)/temp and /gpkg/test_@Value(attribute).gpkg.zip and use this attribute as 'dataset' in the Feature Writer.
liamfez
  • May 3, 2024
Well, that is certainly odd though I am glad that the FeatureWriter method is working. Have you tried moving the /temp down to the fanout?
catherinevachon
I got the same error
liamfez
  • May 7, 2024
Hmm, you may want to reach out for a support ticket.
