Flow's map based data distribution
hlynur
Hello you all and perhaps especially ​@LizAtSafe
Gone through this tutorial here:
Using the Geometry Parameter – FME Support Center
And this is of great help, just have one question that I cant figure out the answer to and that is if the selection map can be set as “Inline” by default instead of “Pop up”, as in that the users have the little imbedded selection map by default when accessing the tool?
With regards,
Best answer by crutledge
Hi ​@hlynur This confused me at first too. In parameters hit the blue arrow and save that parameter set up in your app.
The map will appear by default (or vice versa) after that.
crutledge
Forum|alt.badge.img+27
  • March 9, 2025
hlynur
  • March 9, 2025
That did the trick! Thanks ​@crutledge
