Feature Information Window pops up when starting Form 2023.2.3.0
  • Jul 5, 2024 3:15 PM UTC
  • 229 views
smclaugh1
Forum|alt.badge.img+8
A Feature Information Window pops up when starting Form 2023.2.3.0. This was an install package from our IT group so there could be something from packaging causing this.
crystalatsafe
Forum|alt.badge.img+32
Hi @smclaugh1
Can you share a screenshot of what you are seeing when you start fme?
If you don’t want to see the feature information window when you start fme you can try closing the feature information window. Once you open fme again that preference should be saved and you will no longer see that window.
If the window has become detached and is showing up as a separate window you can reattach it by dragging and dropping it over to anywhere on the canvas. You can then close the window if you don’t want it to appear when you open fme again.
If this doesn’t work you can try restoring the default layout.
Keep in mind this will reset the layout to the default so if you have a customized layout it may not be best to use this.
Please let me know if this fixed the issue.
Crystal
smclaugh1
  • Jul 10, 2024 6:12 PM UTC
It has gone away, it was just a large, blank feature information window. It stopped popping up after the 4th or 5th time I started Form.
crystalatsafe
Hi @smclaugh1
Glad to hear it has gone away! Please let us know if it becomes an issue again.
