Error running FME workspace after FME flow upgrade to 2025.2.1
  • Jan 20, 2026 10:08 PM UTC
  • 244 views
suryakant1990
We recently upgraded our FME Flow from version 2019 to FME 2025.2.1. Although we encountered several issues during the upgrade, the system is now running. However, we are facing a new error when executing an existing workbench.
The workbench reads data from an Oracle table and generates GML and GeoJSON files. The files are generated successfully, but at the end of the process, the following error appears:
190  2026-1-20 14:33:00 | Router and Unexpected Input Remover (RoutingFactory):
No geometry mapping entry found for 'fme_line' in metafile
'E:\Server\fme\metafile\ORACLE_SPATIAL.fmf'.
Please visit http://www.safe.com/support
Has anyone encountered this issue before? Any guidance would be appreciated.
Best answer by j.botterill
Questions:
  1. I assume your Workbench (FME Form) is same version as Flow?
  2. Were you previously using 2019 FME in 32bit… or the now 64bit How to Setup an Oracle Instant Client for Use with FME – FME Support Center
  3. For the table you are reading, which version is the oracle database?
  4. Is that E drive path reachable from the latest Flow machine? You may need to check the environmental variables (for oracle “PATH” between old and new flow)
Compatibility:
Here is an article about compatibility between FME and Oracle RDBMS FME & Oracle Compatibility – FME Support Center
Workaround:
  1. You might be able to switch reader over to Oracle JDBC Driver format?
  2. Try to identify the problem features, using GeometryFilter to find arcs/ellipses and stroke them into lines… which geojson supports
j.botterill
Forum|alt.badge.img+69
  • Jan 21, 2026 7:04 AM UTC
Questions:
Compatibility:
Workaround:
suryakant1990
  • Jan 30, 2026 6:48 PM UTC
Thank you, ​@j.botterill , for your suggestions — they were extremely helpful in debugging this issue together with the Safe team.
It turns out this is a bug in FME 2025 FORM/FLOW. Safe has logged the issue and is currently working on a fix.
The GeometryPropertyExtractor and GeometryNameExtractor transformers are not detecting geometry correctly and are returning errors.
Additionally, the reader is unable to handle multiple geospatial columns, which is contributing to the problem.
crystalatsafe
Forum|alt.badge.img+32
Hi ​@suryakant1990
I wanted to provide an update.
A new build was released that includes a fix for this issue (FME 2025.2.4 Build 25835).
You can download it at: safe.com/downloads/
