Error message while trying to install FME transformer from the FME Hub.
  • Nov 4, 2026 10:39 AM UTC
  • 31 views
mklein
Hi All,
A couple of months ago, i made a post talking about making a transformer available for all users within a APP-V package. I managed making this with extra IT tooling, but in the mean time our new workplace is live and we are working with a newer concept. Now i we installed FME 2026.3.1.1 locally on our endpoints and we are seeing good results.
However when trying to install a transformer from the hub, i am seeing following error message.
ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: 'C:\\Users\\user\\AppData\\Local\\Temp\\pip-target-y7004105\\lib\\python\\fme_emailer-3.11.1.dist-info\\INSTALLER'
Any reason why this is popping up?
nickcumming
Forum|alt.badge.img+14
Hi mklein,
The failure is inside pip’s own temp staging folder (%LOCALAPPDATA%\Temp\pip-target-*\...\INSTALLER), not the package destination. I think pip had extracted all the files and failed when writing INSTALLER. There are a few different things that could block the installer, such as antivirus/EDR or a security policy.
Is this specific to Emailer, or does it affect every Hub package that installs Python? A good test might be to try redirecting TEMP to a plain folder owned by the user.
Have you tried launching FME elevated? If you are stuck feel free to create a support ticket and we can work together to diagnose the issue.
mklein
  • Nov 5, 2026 8:42 AM UTC
No, will definitely try this. Only thing i am currently experiencing, is that it seems to be really hard to get a admin or a admin privileged installer targeting the appdata folder and having FME detect the transformers. As my main goal would be to deploy these transformers to our users instead of giving them admin rights and creating a security leak.
