Any modification to Smallworld Translators between the versions, 2023.1.2 & 2023.2.3?
  • May 1, 2024 1:33 AM UTC
  • 85 views
dammana
Participant
According to the GE Documentation Smallworld 5.3.3. has been officially tested/validated with FME 2023 version 2023.1.2.
We would like to upgrade our current FME Server and FME Desktop 2021.2.x 32 bit.
To consider FME 2023.2.3, I would like to know if there are any modification to Smallworld Translators between the versions, 2023.1.2 & 2023.2.3?
kailinatsafe
Forum|alt.badge.img+24
Hello @deepthiammana, there were not any major changes to the Smallworld format between those versions. If you are curious to see what is different between versions, I recommend taking a look at the FME Change Logs! This won’t show all changes, but should log more major ones! Happy to help, Kailin.
