Another parameter bug
  • Sep 11, 2024 2:04 PM UTC
  • 108 views
paalpedersen
Forum|alt.badge.img+8
Ok,
So we are still using FME flow 2023.2. And its been a while since making those choice parameters. So I thought I would make one to select environment. So the display settings is important to be short and cool, while the value can be long and hard. so I published the workspace as a datastreaming service, and thought for sure my param value should be that of the display values. but no, datastreaming wants my full grose value as an input. This is so annoying, is this fixed in 2024 version? and where is the bug report form?
I dont like negative posts, but I have no choice now..
dylan.at.safe
Forum|alt.badge.img+9
Hi @paalpedersen
It sounds like you’re running into some frustrating behaviour with the choice parameters.
If you believe this is a bug, you can report it by submitting a support ticket. To help us resolve the issue as quickly as possible, please include the following:
  • Screenshots of what you're observing
  • Information about the observed vs. expected behaviour: Did this work correctly in previous versions you've used?
  • An example workspace that replicates the issue, if possible
  • Relevant job logs showing how FME is translating the parameters
Hope this helps!
