After new SSL certificate FME Flow apps complains about Rest API
  • Feb 17, 2025 7:07 AM UTC
  • 170 views
worjak
Forum|alt.badge.img+4
 I updated the pfx cetificate file according to this :
Configuring for HTTPS
Basically updating these lines i server.xml:
keystoreFile="<file>"
keystorePass="<password>"
Now apps complains about REST API? Why? - what to do?
What is the realtion between the SSL certificate and the FME flow Rest API? Where to find information about this?
Best answer by worjak
Ok, thanks. I found out. Since my friends in the IT-department changede the Certificate issuer from a commercial (Trusted CA) to a company issued certificate I need to do an extra step in the configuration procedure (Configuring for HTTPS).
So step 6 is not optional for my setup but the task is quite easy - you just have to know!
I didn’t realise what the change meant till now. It has some benefits regarding cost and maintance.
j.botterill
Forum|alt.badge.img+69
  • Feb 17, 2025 7:45 AM UTC
Hi Worjak, maybe start your troubleshooting using this guide
By securing the FME Flow REST API with an SSL certificate, you ensure that sensitive information, such as login credentials and data payloads, is protected during transmission. The REST API is responsible for all actions under the Flow UI.
  1. Are you using a FQDN url instead of the machine URL that comes by default when it was http?  Maybe your IT needs to make an entry in the domain. Or you need to update the server.xml WEB_URL
  2. Check you have correctly entered the path and file by navigating to the .keystore and double check your text in Server.xml.      keystoreFile="<FMEFlowDir>\Utilities\jre\bin\tomcat.keystore"
  3. You can access the tomcat and Catalina.logs on the FME host machine and find out what errors it might be complaining about. <FMEServerDir>\Utilities\tomcat\logs
worjak
  • Feb 17, 2025 3:41 PM UTC
