Character encoding API Data Virtualization endpoint POST and PUT
  • Oct 24, 2025 12:35 PM UTC
  • 134 views
kdrygalski
I’m having a problem with my API endpoint (both PUT and POST). It’s supposed to insert or update records in a PostgreSQL database. The database encoding is set to UTF-8, but unfortunately, any text data I send ends up stored with garbled characters (e.g. Polish letters are replaced by strange symbols).
It doesn’t matter whether I call the endpoint from postman or directly from a browser the result is the same.
Has anyone run into a similar issue?
payload: {
  "lok_miejscowosc": "Poznań"
Content-Type application/json; charset=UTF-8
db result:
lok_miejscowosc|
PoznaÅ„        |
zoe.forbes
Forum|alt.badge.img+11
  • Oct 24, 2025 5:55 PM UTC
Hi ​@kdrygalski,
Sorry to hear you’ve encountered this bug. It’s known to us and is of high priority, with a fix expected in 2025.2. The encoding issue happens on Windows when the payload is received by the Data Virtualization reader, meaning the two workarounds I can suggest are:
For your reference, this bug is known internally as FMEFLOW-25711.
kdrygalski
  • Oct 27, 2025 8:42 AM UTC
Thank you for your reply. I have to wait for an official fix. The String Replacer can’t help because the workspace receives corrupted characters before it even starts.
