XSLTProcessor fails when using Configuration Type 'Attribute as Stylesheet'
  • Jul 25, 2018 5:48 PM UTC
  • 136 views
friesewoudloper
Participant
I'd like to update the attribute metadata of our feature classes in the ArcSDE Enterprise Geodatabase. The attribute names and descriptions are in an Excel-file. There is already existing metadata (e.g. a description of the feature class and publication date) that I would like to keep. So I want to update the existing metadata.
For testing purposes I created attached workspace and Excel-file.
I use an XSLTProcessor - and not an XMLUpdater - because the number of attributes may vary between feature classes.
The XSLTProcessor needs a stylesheet as input. This stylesheet is dynamically created based upon the attribute information in the Excel-spreadsheet.
When I select 'Attribute with stylesheet' as the Configuration Type and choose the dynamically created attribute 'stylesheet', the XSLTProcessor raises an error on execution:
XML warning: Fatal Error: invalid document structure (Occurred in an unknown entity, at line 1, column 1.)
XSLTProcessor(XSLTFactory): Unable to transform original doc with the stylesheet given. SAXParseException: invalid document structure (Occurred in an unknown entity, at line 1, column 1.)
However, when I choose 'embedded stylesheet' and copy & paste the output of the AttributeCreator_2 from the DataInspector to the 'embedded' parameter in the XSLTProcessor, everything works just fine. The data are processed correctly.
I don't understand what causes this behaviour and how I can fix this. Can you help me out?
Best answer by friesewoudloper
arcsde-attribute-metadata.fmw
@stalknecht I solved the problem thanks to this blog post of @takashi:
http://fme-memorandum-takashi.blogspot.com/2013/10/join-on-parameter-of-featuremerger.html?m=1
I still use FeatureMerger, but the workspace is tidier because it's an unconditional merge.
If you have any suggestions on how to improve my workspace, I would love to hear them.
stalknecht
Forum|alt.badge.img+22
  • Jul 25, 2018 7:24 PM UTC
Could you upload the workspace again? The link is broken.
friesewoudloper
Participant
update-arcsde-attribute-metadata-revised.fmw
This morning, after a good night's sleep, I realised that I have to merge the feature containing the stylesheet attribute with the feature containing the metadata, instead of append.
With a FeatureMerger I solved the problem. However, it leaves me with a cluttered workspace. I'd like to use VariableSetter and VariableRetriever instead. But the variable is read, before it is set. Could someone please point out to me how I can solve this?
friesewoudloper
Participant
  • Participant
  • Jul 26, 2018 6:55 PM UTC
jdh
Forum|alt.badge.img+41
  • Jul 26, 2018 7:10 PM UTC
The aggregator is a blocking transformer, so reader order alone cannot guarantee that the VariableSetter will fire before the variableRetriever.
Have you considered having the OBJ data being read in by a featureReader, that is triggered by the xls feature? Essentially instead of a VariableSetter, a featureReader with merge attributes.
