Xml to shp
  • Jan 30, 2026 9:28 AM UTC
  • 6 replies
  • 412 views
nath
Forum|alt.badge.img+7
Can anyone help me read and write an XML file to SHPs? I've already managed to read it, but then I have to map everything myself, but I've found XSD schemas. I should use two, but I can't get it to work.
According to Copilot, FME 2025.1 no longer supports XSD schemas, but they don't really offer me an alternative either. Nothing they suggest works or is correct.
So I think I'm better off with your expertise than with AI :-)
hkingsbury
Forum|alt.badge.img+73
  • Feb 1, 2026 7:37 PM UTC
A good starting point would be using the Generate Workspace functionality. Depending on your version, will depend what menu it is under (either File or Build), alternatively the keyboard Shortcut is Ctrl+G.
This will bring up a short wizard that asks you to specify your input data, and then specify the output format and location.
nath
  • Feb 2, 2026 10:12 AM UTC
Unfortunately, this gives an error. Or maybe I have the parameters wrong. But I have already managed to read it in and also to write it away, but I want to use the xsd schemas.
hkingsbury
  • Feb 2, 2026 6:50 PM UTC
nath
  • Feb 4, 2026 12:13 PM UTC
Apparently, it's because it's an INSPIRE-based XML. I also need two XSD schemas. I would then have to read it in as a GML. I can load it and save it as a shapefile, but I have to do all the intermediate steps manually. I can't seem to use those XSDs. I'm going to give up for now because I've already spent too much time on it.
daveatsafe
Forum|alt.badge.img+24
  • Feb 4, 2026 3:26 PM UTC
Hi ​@nath,
FME has a dedicated Inspire reader (https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/inspire/inspire.htm?Highlight=Inspire). Is this reader able to read your XML data?
nath
  • Feb 10, 2026 7:49 AM UTC
Thank you for all your help. It turned out that the data wasn't pure Inspire data either. I gave up and imported it without using the xsd and mapped everything manually. It's certainly not perfect or complete, but I can work with it for now.
