XML flatten - holding parent ID
  • Apr 8, 2020 2:28 PM UTC
  • 5 replies
  • 137 views
Hi I have a problem in FME desktop 2019.2 that i haven't been able to solve for a while.
I have an XML response from one server API and i need to restructure it to Post it to another server on a regular time interval. I am having trouble flattening the XML out and holding the relationship to the parent. Sounds like a common question. I can see many people asking similar questions in the forum however I cannot apply the logic to solve my problem. I assume the solution lies somewhere in the reader or flatten settings. The number of children per entry varies as you will see in the example.
In summary:
Input is an xml file. I have created an example attached.
I need to split this into 2 tables. The first is the client information. The second is the contacts. And the relationship needs to be maintained. I was hoping to use the <client> <name> as the unique key in both tables.
Output required is 2 tables or XML files.
I would really appreciate any help.
Best answer by takashi
Hi @jrphilipp, you can read each Client feature containing its Contact elements (XML fragments) stored in a list attribute with this reader parameters setting. The list name would be xml_fragment_Contact{} in this case.
You can then keep the parent (client) ID attributes, explode the list, and flatten each Contact element to extract its attributes, as in:
Hope this helps.
  • Apr 8, 2020 3:57 PM UTC
Hope this helps.
  • Apr 8, 2020 4:10 PM UTC
Hope this helps.
Alternatively you can merge Client ID attributes to Contact features using xml_id and xml_parent_id as join key. e.g.
  • Apr 14, 2020 1:37 AM UTC
Hope this helps.
Thanks you takashi. I will try that. Sorry for the late reply. Appreciate the help.
  • Apr 14, 2020 6:18 AM UTC
Hi Takashi
I am having trouble with the flattener parameters to extract the last component. Would you be able to point me in the right direction? I have tried to read the documentation on this transformer however without any examples i am struggling to understand the inputs.
FME flattener.fmw
  • Apr 14, 2020 3:17 PM UTC
The XMLFlattener parameters should be:
