Wrong result only when using "Run workspace"
  • Jan 22, 2026 10:22 AM UTC
  • 74 views
aaarnm
Hi!
I have a workspace containing four Writers that write tables to a geodatabase. One of the writers is not working as expected. When i press “Run workspace” some of the attributes get null on almost all of the rows. It seems to filtered on one of the attributes (an attrribute called Name) since it is the same names that ends up null. The transformer in the step just before the writer looks as it should, so something goes wrong in the writer, not somewhere in the workspace. The strange thing is that when i press “Run to this” on the problematic writer, everything works as expected and there is no null values anymore.
I don’t get any error messages. Using FME Workbench 2025.2
Hope someone has any idea of what could be wrong, or if it is a bug?
j.botterill
Forum|alt.badge.img+69
  • Jan 23, 2026 3:13 AM UTC
not sure I understand the complexity here well. If possible hit “Share” and attach the Workspace workspace with sample data (an fme template can save the cache as FMWT). Alternatively screen shots with the exposed attributes shown (collapse reader/writer/transformers to show the schema/attributes)
