writing vector and image to PDF
  • Jan 19, 2018 7:30 PM UTC
  • 5 replies
  • 221 views
boubcher
Forum|alt.badge.img+11
looking to write in pdf file a polygon with a raster image clipped to. they will be 2 views one closer view and second with fare view
Any suggestions
LizAtSafe
Forum|alt.badge.img+27
  • Jan 19, 2018 8:18 PM UTC
boubcher
  • Jan 20, 2018 6:31 PM UTC
Thanks for the info,
I manage to create a WS ( staticmap-to-pdf.fmwt), using imageFetcher transformer, the only problem is the PDF is writing only, the image, not the vector
Any thoughts please
Thanks
gio
Forum|alt.badge.img+15
  • Jan 22, 2018 2:18 PM UTC
Actually your geometry is projected above the image raster...very tiny.
You see 2 objects entering the pdf-writer the raster and the geometry.
If you put the geometry in a separate input on the PDF-Formatter, align (using a affiner and the center points) them and give them the same page object size the geometry will be bigger. But not the same size still.
But the map api automatically sets a margin so more work is needed to get them to align exactly.
boubcher
  • Jan 22, 2018 4:32 PM UTC
Thanks
but if we do it as 2 entry to the PDF , we will have a problem to get the right size and location
is there any sugestion on how we could fetch the image then project the vector , then write it to the PDF , this way we could avoid any position issue
gio
  • Jan 22, 2018 4:39 PM UTC
somehow you need to extract the projection.
Looks like you fair better using the script examples rather then the imagefetcher.
Got more control over the google map api.
With fme I got as far as this...using the api url. Can set margin to 0, but not height to 100% on the url. (or at least I failed in doing so)
