Writing to SOSI
  • Dec 12, 2014 8:02 AM UTC
  • 6 replies
  • 119 views
On the FME Server I get an error when writing to SOSI. "504
ERROR
0.0
9.0
2014-12-12 08:44:20
BADNEWS: File C:\\apps\\FMEServer\\Server\\fme\\metafile\\SOSI.fmf could not be opened (tabrdr.cpp:1048)"
A workspace is tested and works well on FME Desktop of course. Is there any special setup for GeoSOSIprofessional when working together with FME Server? Tips?
Best answer by z77
As I installed GeoSOSI after installing FME Server, FME Server should be restarted. I forgot it. Now it works well. So there was no need for separate installation.
  • Dec 12, 2014 11:21 AM UTC
it's quite possible that you have to do a separate install of GeoSOSI Professional on FMEServer (probably into the c:\\apps\\FMEServer\\Server\\fme directory).
If that doesn't work, consider contacting Geodata support.
David
  • Dec 12, 2014 11:28 AM UTC
Yea. It could be as you are suggesting. I will still wait If SigTill has somehing to add on this topic. :)
  • Dec 12, 2014 2:13 PM UTC
SigTill jobber vel for konkurrenten. Han vil sikkert helst selge deg sin egen plugin ;-)
  • Dec 15, 2014 6:56 AM UTC
LOL, but that's life, that's business :P
  • Dec 15, 2014 10:39 AM UTC
sigtill
Forum|alt.badge.img+25
  • Jun 1, 2015 8:38 PM UTC
Haha, I googled my name and found this thread :). For the record - you dont need to restart FME Server for the GDMMapper-plugin to work :). And also you can have both the GeoSOSI and GDMMapper installed at the same time if you have the GDMMapper 2015- version. Just let me know and I`ll send you a free demo (sigher@norkart.no)
