Writing to KML with ExtendedData
  • Apr 18, 2013 2:50 AM UTC
  • 107 views
I am new to FME, and am in the process of creating a workbench (in FME Desktop 2013) that joins an ArcSDE Feature Class to an Oracle Table, and writes the output to KML.
I was fairly successful, but am having difficulties in writing arbitary/additional XML data using <ExtendedData>.  See this link for info about KML Extended Data (scroll to the bottom for the arbitary XML part)
https://developers.google.com/kml/documentation/extendeddata
I would like to include the following in the KML:
ExtendedData using xmlns:pdif="http://www....."
  • pdif:Agency
  • pdif.Status
  • pdif.StartDate
  • pdif.EndDate
Values for these fields will come from the joined data.  I am not sure how to do this, and would appreciate any help/input.
The ExtendedData required are in addition to some other fields such as Name, Description, Geometry, etc.
Thanks for your time and consideration.
Regards,
Sendhil
mark2atsafe
Forum|alt.badge.img+59
Hi Sendhil,
The FME Readers and Writers Manual will help you out here. You can access it through Help > FME Readers and Writers in the menubar of Workbench.
Navigate to Google Earth KML > Feature Represenation > Extended Data. Here you will see the names of the attributes you need to use to create extended data.
Basically you need to create list attributes, kml_data{}.name and kml_data{}.value. If you need there is also kml_schema_url to define the URL of the schema being used.
I hope this helps to answer your question,
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
srg
Forum|alt.badge.img+10
  • Apr 18, 2013 4:45 PM UTC
Sendhil,
Looking at the screenshots in the link sent by you,could I ask you to check out KMLPropertySetter transformer in FME Workbench?
http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/kmlpropertysetter.htm
Cheers
SRG
  • Apr 22, 2013 5:30 PM UTC
SRG / Mark:
Thanks for your responses.  I was able to make a bit more progress based on your input.  Here is where I am:
I was able to get the data to look like this:
<Placemark id="kml_1"> <name>Test Project</name> <description>Installation of Infrastructure.</description> <styleUrl>Road Construction</styleUrl> <ExtendedData> <SchemaData schemaUrl="#kml_schema_ft_CIP_FACILITIES"> <SimpleData name="Agency">Henderson</SimpleData> <SimpleData name="StartDate">07/01/2013</SimpleData> <SimpleData name="EndDate">06/30/2015</SimpleData> <SimpleData name="Contact">John Doe</SimpleData> <SimpleData name="AProjectID">X-251</SimpleData> </SchemaData> </ExtendedData> <Point> <coordinates>-113.92,36.213,0 </coordinates> </Point> </Placemark>
I am trying to get the data to look like this:
<Placemark id="kml_1"> <name>Test Project</name> <description>Installation of Infrastructure.</description> <styleUrl>Road Construction</styleUrl> <ExtendedData xmlns:pdif="http://www.rtcnv.com/pdif/1.0"> <pdif:Agency>Henderson</pdif:Agency> <pdif:StartDate>07/01/2013</pdif:StartDate> <pdif:EndDate>06/30/2015</pdif:EndDate> <pdif:Contact>John Doe</pdif:Contact> <pdif:AProjectID>X-251</pdif:AProjectID> </ExtendedData> <Point> <coordinates>-113.92,36.213,0 </coordinates> </Point> </Placemark>
I tried using the km_extended_xmlns_prefix (=pdif) and  km_extended_xmlns_url (=http://www.rtcnv.com/pdif/1.0) format attributes, but that removes the whole ExtendedData block.
Any ideas on what I am missing or doing wrong?
Thanks,
Sendhil
  • Apr 22, 2013 5:38 PM UTC
The format attributes were kml_extended_data_xmlns_prefix and kml_extended_data_xmlns_url - just discovered the typo I had made earlier.
