Writing PostGIS - CompoundCurve
  • Sep 27, 2019 3:48 PM UTC
  • 8 replies
  • 290 views
Hello
I try to write Polyline-Geometry from ESRI Personal Geodatabase to PostGIS (Version 2.5) with geometry typ CompoundCurve. With PathBuilder I am successful to build Paths with Segments with only IFMELine or mixed IFMELine/IFMEArc and to import them.
But I am not able to write Paths with only Arcs to PostGIS. The import fails with following message:
Error executing SQL command ('INSERT INTO ...
Geometry type (CircularString) does not match column type (CompoundCurve)
Any Ideas? Thank you.
  • Sep 27, 2019 3:51 PM UTC
When creating the writer, try disabling the generic spatial column type:
  • Sep 30, 2019 3:36 PM UTC
Now the features could be imported. Thank you for the quick answer.
My question: is the restriction, that Arcs building a segment are not allowed in CompoundCurve-Geometry, set by PostGIS?
  • Sep 30, 2019 4:03 PM UTC
Good to hear that it worked.
I don't understand your question, however. Can you perhaps give an example?
  • Oct 1, 2019 3:22 PM UTC
Sorry for confusions.
My Personal Geodatabase holds a feature class with features consisting of lines and curves (topology without errors). I created now in PostgreSQL a table with PostGIS-Geometry CompoundCurve. I can import most of the features from Personal Geodatabase into that table. But the translation stops at following feature - a closed feature with 18 arcs:
Error message:
Error executing SQL command ('INSERT INTO "test"."gew_abschnitt_compoundcurve" ("id", "route_id", "geom") values (7388, E'07.13-03.02', '0108...'): 'FEHLER: Geometry type (CircularString) does not match column type (CompoundCurve)
Does the geometry type CompoundCurve not support connected Arcs? (The import works with single Arcs, Lines and mixed Lines/Arcs.)
When I uncheck 'Create Generic Spatial Columns' as you suggested, the error does not appear and I can import the feature. Why?
  • Oct 1, 2019 4:02 PM UTC
Error message:
What happens if you set the FME PostGIS writer geometry type to "postgis_multicurve"?
See also https://giswiki.hsr.ch/PostGIS_-_Tipps_und_Tricks#Curved_Geometries
  • Oct 2, 2019 11:39 AM UTC
There is no difference with MultiCurve geometry. There appears no error, as soon as I uncheck 'Create Generic Spatial Columns'.
The database shows the correct geometries, when the import is successful. I marked the feature mentioned above, consisting of arcs only:
I don't understand, why the workbench uses the parameter, though I import the features in already existing table. I don't create a new one in my translation.
What does the parameter in detail?
  • Oct 2, 2019 1:13 PM UTC
This is beyond me, my recommendation is to contact Safe support and also point them back to this thread.
  • Oct 3, 2019 5:46 AM UTC
O.K. Thank you for your help.
