writing metadata
  • October 14, 2013
  • 23 views
Hi everybody.
I have checked the tutorials on how to write metadata  but am troubled. it seems like FME includes extra xml tags causing ArcCatalog  not to recognize the metadata. I have included the tags in the text below.
What am I doing wrong? any pointers?
-<fme:xml-tables xsi:schemaLocation="http://www.safe.com/xml/xmltables signs.xsd" >
-<fme:NewFeatureType-table>
-<fme:NewFeatureType>
 <fme:geodb_metadata_string>
METADATA GOES HERE
 </fme:NewFeatureType>
 </fme:NewFeatureType-table>
 </fme:xml-tables>
  • October 14, 2013
I have not observed this myself. I have used ArcCatalog to export an empty metadata template into xml, which I then used as boilerplate in FME. Works very well.
Can you show us the entire XML that you´re posting?
David
  • October 16, 2013
David. Sorry for the late response. I can t post the rest of the xml as its for a confidential client. I think I know what might be causing the problem.  If I understood correctly, you just export the metadata in catalog and use that xml as a document to be modified?
I appreciate the time and guidance Thanks man
