Writing LARGE datasets to ArcGIS Online
  • May 14, 2019 10:19 PM UTC
  • 8 replies
  • 333 views
runneals
Forum|alt.badge.img+32
Working with esri and the developers for ArcGIS Online, we came up with this script that can be used on shutdown. You will need to write data out to a zipped file geodatabase (or other formats), then configure the script.
Only works with 2019.x+ as it requires you to use ArcGIS Pro (tested in 2.3). It does take a while to run (as it has to use the ArcGIS Python library), but is SUPER efficient when trying to write LARGE datasets to ArcGIS Online. It is much preferred over using the FME writer because that one uses the traditional database insert for each record while this is similar to bulk inserts. Can probably be modified for writing to Portal as well.
https://github.com/runneals/GISProjects/tree/master/agol/Append
cc @carsonlam @bruceharold @mmccart
bruceharold
Forum|alt.badge.img+19
  • May 14, 2019 10:46 PM UTC
Very cool David. Also check it out @1spatialdave
bruceharold
  • May 15, 2019 2:43 PM UTC
@carsonlam Hi, this question could be refactored as an idea, namely to support bulk appends when the arcgis Python API is available, with and without truncate. Personally I use Pro to populate feature services and use DI/FME for maintenance operations but others may like a bulk writer.
carsonlam
Forum|alt.badge.img+7
  • May 15, 2019 4:28 PM UTC
Is there a similar bulk append mechanism in the ArcGIS REST API?
bruceharold
  • May 15, 2019 4:42 PM UTC
LizAtSafe
Forum|alt.badge.img+26
  • May 15, 2019 4:56 PM UTC
Hi @bruceharold,
Unfortunately we cannot convert questions to ideas, but I have created the idea for you to vote on. Please see Support bulk appends when the ArcGIS Python API becomes available
- Liz
cc: @runneals, @mmccart, @1spatialdave, @carsonlam
bruceharold
  • May 15, 2019 6:11 PM UTC
Hi @bruceharold,
- Liz
Thanks Liz! Maybe Carson will make an end run around the idea and do it with the REST API so there is no ArcGIS dependency. I'm seeing a lot of action with bulk work to AGOL so it will be popular.
runneals
  • May 15, 2019 8:22 PM UTC
Great minds think alike @carsonlam :) I was going to go that way with the next enhancements for improving the script, as using the ArcGIS Pro API requires quite a bit of overhead and increases the run time quite a bit. However my workload exceeds my free time, so probably won't be happening for a while on my end.
If you need a use case, we have a workspace that runs every week that updates historic rail lines in Iowa that takes almost 30 minutes to run, and almost 20 minutes of that is just writing data up to ArcGIS online, so using this bulk append method would only take a couple minutes and speed it up quite a bit.
runneals
  • Jun 14, 2019 4:24 PM UTC
I was successfully able to get over the major issue when the file geodatabase would get stuck on ArcGIS Online due to the delete portion of the script not being executed. See the sample below for the best implementation that works now (using feature writer and a python caller)!
Sample_Workspace_AGOL_Append_PUBLIC.fmw
