writing in acad blocks
  • May 6, 2015 6:57 AM UTC
  • 71 views
franco69
Forum|alt.badge.img+11
Source is a shape file (point) with certain attrbs....(screenshot)
GNR is a parcel nr. which i want to show with an arrow to the parcel (because these are little parcels and there is not enough space for the number)
ROT_GNR is the rotation for the number
RW_PFNR and HW_PFNR are the coordinates for the number (because they are different to the coordinates of the point)
thats all clear but I've tried and tried to get this right but i have no ideas left because i have to place this in an AUTOCAD block called GNP
screenshot 1 shows the block in AUTOCAD as it should be
screenshot 2 is from blockeditor from this block:
as you see the arrow has Layer PN
screenshot 3 also from Blockeditor
as you see the number placed in Layer PNA and thats my challenge....I cant find the way which attributes i have to fill (inserts, rotations, block_insert, text_inserts,etc....) because there are two layer definitions in one block and as a source i have one shape file.
Sometimes the arrow appears only, sometimes only the text, and so on....so maybe someone could help me?
Thanks a lot
Franco
pratap
Forum|alt.badge.img+12
  • May 8, 2015 6:30 AM UTC
Is it solved ??? If not please provide sample data of both dwg and shape file.
Regards
Pratap
franco69
  • May 26, 2015 12:19 PM UTC
it isnt solved yet.....
