Writing attachments to portal
  • Oct 23, 2019 4:12 PM UTC
  • 5 replies
  • 178 views
Hi All, I was wondering if its possible to retrieve attachments from one feature service in portal and insert them into another table within a different feature service in portal. I am able to read the attachments however i dont understand how to write these attachments back to another table without using the arcpy interpreters.
jovitaatsafe
Forum|alt.badge.img+11
Hi @jessebrid,
Unfortunately we're only able to read attachments from ArcGIS portal, and cannot write them currently according to the Writer overview. In this similar idea (but for ArcGIS Online), Trent suggests a HUB workspace that will work for both AGOL and ArcPortal as a starting point. There's more info on it directly in the FME Hub for the AttachmentWriter.
Hi @jessebrid,
Hi @jovitaatsafe​
Do you have any updates on this considering newer versions of FME?
Greets,
Vincent
nampreetatsafe
Forum|alt.badge.img+14
Hi @jovitaatsafe​
Greets,
Vincent
Thanks for enquiring @vincentvanderwo​! Unfortunately, there aren't any updates on the development side of supporting attachment support for the ArcGIS Portal Writer (internal reference FMEENGINE-40499). I will add your interest about this to our internal ticket for this. Thanks!
Hi @nampreetatsafe​, thanks for the update :)
rmurphy
Forum|alt.badge.img+9
  • Mar 29, 2023 4:17 PM UTC
Hi @jovitaatsafe​
Greets,
Vincent
Has the ability to write attachments to a Portal feature service been implemented yet (i.e. FMEENGINE-40499)?
